Pull the plugs and squirt a little oil down each one.. then put them back.. Use starting fluid in the Brake Booster Feed Line to the intake Manifold.. Have someone crank while you spray it in.. If you have spark, it will lite and run.. Like Krap for a bit till things seal up.. Cj
